driveshaft yokes
futten
where can i get all the parts for building a driveshaft? i have a 7,5 10 bolt and will be using a muncie m-21 or saginaw 4 speed cant use any stock lengths because ill be moving the engine in my car backwards
that would all good and great it i had a local driveline shop but i dont
There useualy all around, look up Mudding 4X4 places or disel truck centers. I'm having one custom made as i type this,the place is called Advance Driveline (but in Florida)...you put power to that 7.5 10 bolt,you'll need the place you find again for new 8.5.....
Enjoy!
Enjoy!
Don't know if they have a location in Norway.
well from advice from charlie the 7,5 will handle the power output of my car sins im not running a turbo and will only be putting out 300 horses and all the internals are going to be alot stronger then stock with a girdle and a center bracing same as charlie did
just measure from trans yoke center to rear axle yoke. make sure you pull out the yoke from the trans a little more than half before you measure to allow for suspension movement. Any good driveshaft shop online should be able to assemble you one based off your measurements and ship it to you.
yoke will depend on some things.
if you have a 65-70 1/2 muncie M21 then the yoke from your th350 should slide right in. same goes for all year saginaws.
if you have a 70 1/2 -74 Muncie M21 then the yoke will need to come from a th400.
so your exsisting yoke should work just fine. if it does not, then you need to properly identify the 4 speed your using.
thats good advice but i still need a yoke for the transmission
What type Universal Joint do you intend to use, Stock size ( N3r ) 27-Spline Slip Yoke or other type/size?
You can narrow your choices here, click options on left:
http://www.summitracing.com/search/...Transmission/Transmission/Manual/?Ns=Rank|Asc
With the DriveShaft installed the Slip Yoke needs at least 3/4" .750" clearance from the end of the Trans Output Shaft, to allow for suspension movement. No more than 1" inch.
asked my friend who was recently in NC hes got a 4 speed from a elcamino he stripped while he was there and it had a saginaw thanks for the advice guys
