bmackinnon
- Feb 24, 2005
When removing the DS header, will it come out the top of the engine compartment? I have all the bolts out, and it's completely loose, but doesn't seem to want to find it's way out the top. I didn't loosen/remove the wire loom that goes across the DS valve cover because I've heard people have a hard time with the studs/nuts that hold it down... so I wanted to ask first before I made any further attempt at a top removal strategy.... I also obviously didn't loosen the crossover at the passenger side header... and the header doesn't appear to want to come out the bottom like that either....
So... I'm left with either moving the loom/wiring out of the way (?) if it will even come out the top?? or loosening the Pass. side of the crossover so I can move it around to get the header out the bottom?? ... which I'd also rather not do, since I may break a bolt and it's sealed up good over there...
Oh... and I have vac. brakes also.... if that matters? The booster might intrude into some space the PM didn't.......
Advice from experience, please?? :redface:
