dual fan kit
Velon
I posted a few threads yesterday regarding the dual fan set up . Thanks to all that replied, I got installed and will be testing out shortly. I have a hot wire kit already installed on the GN. Does anybody know if I will need more volt boosting besides this if these dual fams draw more current. Thanks
Andy
I ended up with the Racetronix hotwire harness for the fans for two reasons, first, my volts would REALLY drop and the factory harness felt a lil warm, and secondly, the RC fans and adapter gave high fan speed only..with the RTX harness the volt drop is nil and I have both speeds again..works great.. If you already have the RTX fan harness you should be fine :)
fans
I do have a hot wire kit but I don't have a hot wire kit specifically for the fans. I bought the fan kit and a wiring adapter for the grand national from ramchargers. i drove the car hard around 16 lbs of boost and its getting good scanmaster numbers so I hope I'm fine. Thanks for the reply.
Andy
