Dual fan's just a bolt in?
B
Broken down
Guest
The fans Ramcharger sells,the one that comes with Harness.Is the harness a plug in for the TR? Does the fan just bolt in? I see it flows 2340 what does the factor one flow?
Thanks,summer is coming...Or is it here can't tell
Let me think..
I trimmed the tabs off and took ~1/2" off hte sides. then it fit between my radiator tanks, flush on the core. Add some foam tale between the fan and rad core, then I made a couple "L" brackets for the top and used the fatory lower mount as the lower mount.
I have some pics somewhere, but if you search for my name and threads you might find them here.
Otherwise try
http://www.turbojim.com:231/jim/fans/FANS.zip
I think thats the url...
I just ordered a set of them this week. The guy at Ramchargers told me that i would have to cut the tabs off and use draw ties to hold them in place. He also told me it was a plug and play harness. I will find out next week.
