Dual feed question
Nasty
empty wallet
I know this was answered not long ago, but looking for absolute certainy.
Dual feed, using CK's plate.
Plate
Block oil feed bolt hole.
Remove either the inner piston seal for the direct drum, the middle/second ring on the center support OR both.
BTW, is there a advantage of one over the other?
Plate
Install drum with billet shaft. There is no advantage over another as long as you do at least one of them.
Just a quick question on this, the seal to remove for the direct drum... is this the seal IN the direct drum or is it the inner middle seal on the piston?
Its got to be the one INSIDE the drum right?? the one on the piston wouldnt make sence?
Im goin a head and doing both the ring and seal, one less seal should mean easier installation :)
