Dual oil filter along with tranny filter
T-Type85David
While my car is down for repair along with putting the posi trac in/axles(maybe,busy), putting an overide fan switch, Basic stuff. Time for an oil change as well. I had plan to do this but wanted feedback(like always) Anyone running dual oil filters if so will this bolt right up? Adaptors will screw right on?
Summit SUM-G4986 - Summit® Oil Filter Relocation Kits - summitracing.com
Along with this i wanted to drain the tranny, put a shift kit along with new fluid (of course) Type F right? I know they have the stock 200-4R filters or the hi flow units.(which to get?) I wanted to know if this will be a good add on.
Summit SUM-G4980 - Summit® Remote Transmission Filters - summitracing.com
I had plan to also add this along to add more transmisson fluid capacity, same idea behind the dual oil filters.
Well any thoughts on this would be great. part # etc thanks;)
there both good, but both can cause excessive pressure drop.
I think a good single filter system will be fine for the motor.
as for the trans, a filter wouldnt hurt... but then again, a drain plug and 45 min to change the stock one isnt too bad.
A.j.
