dumb question
jerritt
hey guys what do i do with this now that i have a different wastegate? the car has be apart for awhile now and if i remeber right after the y coming off the boost solinoid one went to the wastegate and one went to this plug but now with this new wastegte what do i do with this plug? and if i read some of these threads right now that i have this wastegate i dont really need that boost solinoid that sits on the passanger side valve cover right? thanks guys
Just put a plug in where the fitting is. You don't need the wastegate solenoid anymore but depending on the chip you are using it may set a code if you unplug the electrical connector.
I assume you are using a replacement chip. Check with the supplier, likely it will not "see" the solenoid and not set a code.
