SignUp Now!Thanks daily driver my car is fast I have a 10sec set-up,but cant you cap it off under the fender.
Theres nothing worst the hearing a car with loud exhaust then see it running a 12.0.
Im going to put a cut-out on my Kirban special for now I have a stock exhaust system
So if your runnin into the 10s and you have a Kirban two peice, that also means your running a stock elbow plus stock exhaust
Wow all that restriction and your in the 10's!!!! man your the new guru, I think we found grumpys competition.![]()
I said set-up I never said my car ran into the tens I have seen several people sell engines on this board and refer to them as 10sec engines, with the parts I have in my engine my motor is set up for some 10's![]()
old school, lot of old timers did this many years ago. Brady Perry comes to mind. Have to cut a hole in the fender well under your over flow. At the Nationals in '91 Brady blew out a front runner when he turned to sharp in the pits after a run. A short pipe was put on for racing.
Have any one ever tried dumping there exhaust coming out of the turbine housing
No im not trying to cut corners I already have the material to make a 3.5 single shot im just experimenting if doesn't work with my combo then well be it.But since were on this topic I have seen two well known Buick guys in North Alabama run similar set-up that have and one ran a 7.25 and one did a 6.90:
