Dump Pipe
lordmikef
My stock GN runs 14.0 with radials. Any predictions after i add a dump pipe, fuel pump and slicks?
Mike Ficacci
New Jersey
Better add.... a fp regulator and something to help tune it.....
then maybe as much as a second......with good brakes....gas and traction with the new tires......
Basically the highest octane unleaded you can find.....100 to 110........(when you get to a point where you switch to a thumbwheel you can run leaded)
I m guessing you have an adjustable actuator rod.(10$)....to control boost? More octane lets you run more boost .....to a point....as long as it doesn t detonate.......this is why you need some kind of scan tool.......
