S
stevec
Guest
Is anyone using this pump with the bypass plugged off completely?? Dutwiller said if plugged the oil filter would rupture. I am using the OBERG filter and dont think it will blow apart. I have plugged the bypass on a stock set up with remote filter Moroso style and dont have any problems. Car mkes 90 psi when cold at idle I dont rev it till it warms up.
Also if I do end up using the by pass can it be TEE into the turbo drain line with no ill effects. I am concerned it might keep the turbo from gravity draining.
Thanks Again
Steve C
Thanks Again
Steve C
