Well, I have just got my car up and running after installing the WB with powerlogger and alky, along with Eric's 6.1 chip for alky. I made some runs to try to log some data. My DC is around 93% with 23lbs of boost. This is with a A/F ratio of 10.8. I want to run 25 lbs of boost however I'm wondering if I have enough injector to run 25 lbs. My fuel pressure is set on 45 with the line off. I'm getting the 1 psi of pressure per 1 psi of boost rise. Do you guys think that the DC is too high and that I need bigger injectors? The car is really pulling hard, I can't wait to run it through the lights.
		 "......more base fuel pressure, may have to re-tune idle and part throttle....."
