dyno/rich
wantan87
So I took my car to the dyno for its first time. And it had 270hp and 390 ft-lbs. The problem with these numbers is that the car was running so rich that it didn't even register on the a/f chart so it was richer then 10.1. I kind of knew i was running rich because when I mash the gas the car wil just bog and not go from a stop, it does a little better from a roll. So I need some tunning pretty bad.
te-45 turbo
206 cam
50lb injectors
p&p stock heads
43psi fuel pressure regulator
turbo tweak chip
running 20lbs of boost
Thats all thats done to the motor. So what do you guys think i need to do smaller injectors
chip
Make sure your chip is for 50# injectors, they should be matched, if the chip is for smaller/stock injectors you'd be rich for sure.
If O.K. look to fuel pressure.
Hmmm this might be kind of hard to figure out then, I guess i'll redo the whole file so i can fit it on here.
What kind of chip, street, race 100, 110, etc, and what fuel were you using?
Regards,
Eric
chip is for 20psi running 100 octane which I was doing. I posted my date logging on t6p.com
