Jerryl
Tall Unvaccinated Chinese Guy
- Dec 14, 2004
........... All it needs to know is the plenum air temp.
when i first put my fast system on my car i didn't relocate the IAT until about a yr later and it had no ill effect on the tune.
But.. one good thing about the iat being in the intake is one woule be able to datalog true air temps through out the run/dyno pull.
also talking about the TC % slip. we are now making almost as much power now with the convertor not locked up @ 2psi less boost over his last dyno pull that was @ 25psi with the convertor locked. so that tells me we must be doing something right![]()
I also don't look @ the Max HP/TQ numbers on a dyno it's just a tool to help tune with kinda like making a change @ the race track and noting how much the MPH went up or down to tell you if you made a change for the better or worse.
All i count for is the ET and not blowing it up :biggrin:
All i can say it's being a learning curve tuning a hot-air over a I/C car. each one like diffrent things.
Don't disagree with the MAT sensor placement, but some may disgaree.
I think the MAT data will suprise you ......... may be not
I think the "perfect MAT sensor" spot is in the runner, but the amount of error is too small for what we try to do.
Of course, "perfect" implies welding up a "boss" and have the sensor barely break the air stream. ........ than again, that only really matters if you have balanced flow in each runner, and, can prove that.
