E-bay intercooler
VernLee
I don't know how to insert link, but the item # is 7922805777
Does any one know if this intercooler will work in our buicks?
looks like it would be easy to front mount, or put where original one goes, any information will be appreciated.
Vern
Any IC will work. However, that one will not work very well.
That IC will work for small displacement engines that are not going to run a lot of boost. That one has fins in the core, and the tubes are really long. That is not good for engines that need to move a lot of air. If it was not bar and plate, and not tube and fin, then it might work.
So NO, do not get that IC. There are a lot of other options out there. You can even try the Powerstroke Diesel IC if you like. If I remember correctly, they are about $300 or so.
Vern, you should do as much reading on this board as possible. It sounds like you are new to the game. There is a TON of stupendous info here to be had, and it is free to you.
I think that by reading the tech section you will have less questions. Maybe you will have more, but you will have the knowledge that countless thousands of us have already found out for you.
This is also info for any other new guy/gal!!
