update** Ran 1/2 a gallon of e85 thru the alky system $1.60 which included wot shots and random spray tests on different pump speed levels, and IMO the meth/denatured alcohol/methyl alcohol seems to cool better... just by test spraying on idle you can feel the difference on the uppipe, i don't have the air temp on the doghouse but feels significantly colder maybe a 20 degree difference when sprayed (by touch)..There is also a difference while driving the a/f seems to suddenly drop and becomes very rich once the e85 is sprayed maybe need to tweak the nozzle or pump speed to see best spray pattern for e85.. so the only way i would want to run e85 thru my custom alky setup would be if i were for example running on 100% e85 and my IDC were nearing over 80-90% i would easily use this method to help out with IDC, and could run same boost levels that would require bigger injectors.. i still think i should do more research when im on 100% e85 i love the fuel its high octane and its a domestic product.. i will update as soon as i do anymore test.
