Flyin Brian
- Jun 18, 2011
Ok, I think I know what I did to cause this but I guess my real question is are my injectors fixable?
I put some 120's in a year or so ago and ended up blowing a headgasket last November. I pulled the motor to work on it. I was planning on putting it back together quickly so I removed the intake manifold and left the injectors and fuel rail in place. I rinsed out the fuel rail with straight gasoline as I know that sitting open with E85 can cause issues (I think I once killed a fuel pressure sender this way). Time passed and I just put the car back together a few days ago. Noticed the rail was losing fuel pressure after key off. Started it and it ran but was backfiring out the exhaust. Key off and rail still did not hold pressure. Pulled plugs and several of them were obviously way rich. Put my 80's back in (which I had carefully cleaned before storage) and it runs fine. Rail holds pressure now. So my 120's are leaking.
Do you think my 120's will clean up or do you think I have ruined them? Opinions appreciated.
