I Know this thread is going to stir up the weak and strengthen a few.. Let's see what happens. I just wanted to post some of my E85 Fuel Tester result's which i test every fill up.. Now, this isn't necessary but i run alot of boost and my puppy is stock to the T. I like to keep my car in running condition always and i also go balls out when racing. As you may have seen in other posts i run 29-30 psi on my stock longblock no special internals or special headbolts. My heads have never been off the block. I have great oil pressure and over 150+ compression on all cylinder's and i always check my plugs as well. So i just wanted to show you how i check my fuel content. I have to agree the ZEX ethanol analyzer is way better but i paid like $12 for my tester could have made it for $2. Well enjoy and also stay tuned for the special twist..
This is the fuel tester .
Fill Water to the specified line.
Fill E85 up to top line, and shake it up.. Then sit patient and see your ethanol content. As you can see this batch is 85%
