TT/Ameasap
The White Blur
- Jan 31, 2002
EMPTY WEIGHT:Never scaled
BLOCK:bored .030 over
HEADS:Weber
CAM: Weber 214/214 .548 lift
TRANSMISSION:Jimmys
TORQUE CONVERTER: Precision 3200 5 disc
DIFFERENTIAL: Strange Dana 60 3.54 detroit locker
INTERCOOLER:Jim Dunn stretch IC for TTA
THROTTLE BODY:68mm
RJC POWER PLATE:yes
INJECTORS:120#
THERMOSTAT:160
TURBOCHARGER:6768HPQ
VALVE SPRINGS:941 comps
MAF: No
DOWN PIPE:THDP
EXHAUST: SLP
FUEL PUMP:Fuelab 1300hp
FUEL PRESSURE REGULATOR:Fuelab electronic
FUEL PRESSURE:46psi
ALCHOHOL INJECTION:yes, but not on.
AIR FILTER AND AIR INTAKE:K&N
TIRE DESIGN, SIZE & AIR PRESSURE: M/T ET street radials 255/55/16
AIR BAG(s):Yes
SUSPENSION: 90/10 struts
SCAN TOOL:scanmaster 2.2 and Power Logger
FUEL: E85
CHIP: TurboTweak
CHIP TIMING:24 in 1,2 and 23 in 3rd
KNOCK RETARD: 3 degrees on 2-3 shift then down 0.2
OXYGEN SENSOR VOLTAGE:780's
EXHAUST GAS TEMPERATURE:n/a
TRACK ELEVATION:900ft
TEMPERATURE:80 degrees
PEAK BOOST: 17.5-18.5
BOOST AT LAUNCH:12-15psi
MILES ON THE CAR/ENGINE: 1k on motor 116k on body
HEADS:Weber
TRANSMISSION:Jimmys
THROTTLE BODY:68mm
RJC POWER PLATE:yes
INJECTORS:120#
THERMOSTAT:160
MAF: No
DOWN PIPE:THDP
EXHAUST: SLP
FUEL PRESSURE:46psi
AIR BAG(s):Yes
FUEL: E85
CHIP: TurboTweak
![IMG_1159[1].JPG](https://turbobuick-data.community.forum/attachments/176/176196-05df43162154c1d65706aa92af8fba18.jpg?hash=Bd9DFiFUwd)
			![IMG_1158[1].JPG](https://turbobuick-data.community.forum/attachments/176/176197-4e5f4b783b4280c1ce617b2783ba77b5.jpg?hash=Tl9LeDtCgM)
