USMC_Turbo6
- Dec 13, 2009
Does anyone have any experience with E85, SD2 CHIP AND TR 6. If so can you please give me your experience and tips on what works and what doesn't.
SignUp Now!Does anyone have any experience with E85, SD2 CHIP AND TR 6. If so can you please give me your experience and tips on what works and what doesn't.
As a starting point, just use the base tune. If using flexfuel, turn on that option. The TR6 doesn't really affect the tune. I would gap around .030".
Ihave had the flex fuel deal for 5-6month . I love it I only have been on the Dyno 1 time and only had 4 runs . I tuned it from 470HP - 510 in the 4 runs . I Have 80 lbs injectors so it's alil small so I spray alil Alky on top to keep the DC down
I will be running ngk 3249 plugs
I recommend not using those plugs with the SD2/Powerlogger (the ngk 3249). They do not have a resistor like a stock plug, and you will be asking for data corruption in the ECM and Powerlogger.
Spark plugs without resistors should not be used with an engine controlled by a computer. I know there are some people that are getting away with it, but I highly recommend not doing that.
Eric
