E85/SD2& TR6
I went with the NGK UR6 plugs at .028 but will regap them to .030. What is the AFR for E85 on a sideband that's for Gas?
I would just leave them at .028 if you already gapped them there.
With a wideband that is displaying AFR for gas, you can tune using typical gas AFR's as a starting point.
If you want a recessed tip plug I use the YR5 with my TR6 gapped a 35. They are the same plug as the UR5 just a non projected tip. I'm a pump gas guy no E85 up here.
