TT/Ameasap
The White Blur
- Jan 31, 2002
I felt the same thing when I was running higher timing last year. Now I am leery about running higher timing at 24psi.
SignUp Now!You're not making sense here. You said "Now if under, you want to shoot for a gas AF of 9.37 = 7.35 E85" To me that sentence reads under boost you want to aim for a 9.37 on the gas scale which comes out to a 7.35 on the E85 scale. Is that not what you meant? I said that 9.37 seems rich which I thought was obvious that I was talking about the gas scale, as you were just talking about that number on the gas scale. Now if you are talking about running boost at 9.37 on the E85 scale, then yes it would be lean as that translates to about a 14:1 on the gas scale. And again 9.37 on the gas scale will not equal 7.35 on the E85 scale. 9.37 would be more like 6.2 on the E85 scale, which is rich as all hell. However going the other way 7.35 on the E85 scale come to about 11.1 on the gas scale which I think is a little rich, but perfectly acceptable AFR.
I also disagree with you about the injector sizing. I would say you need about 50% larger to make the same power...so 60lb injectors, for example, would become 90lb as 60 x 1.5= 90
I really wouldnt go much over 24-25 degrees no matter what the scenario just cause Im more concerned with preignition than detonation with ethanol....torched a head gasket in half a second with a tune hiccup on my other car on the corn....that fuel will make you feel like superman and take anything you throw at it...but cross the line and its a quick rod in the ass...
I agree that you can run more timing. I would even step out and say, that you could run around 27* on 24#. But your tune has to be right.... Spark/ignition is the cooling factor of the motor. There are tuners out there that have experimented with detonation and egt. As they started to get detonation, their egt started to drop. Hense the cooling factor. Now the fuel is where we start to see our heat. The excess/extra of fuel on the cylinder walls and ring lands are where and why we get that burnt piston, rings, and head gaskets.
I let me fingers do the talking and proof read. What I was saying, that with the SD Chip and the classic fast, you want to have your WOT Target AF around 7.35 (E85) /9.37(gas) scale. 9.9 E85 is equivalent to 14.7 gas AF. I will disagree with you again on 7.35 (give or take a little) as to being to rich. These cars love the E85 and at WOT...... This is why you are allow to run more timing and boost........
I personally havent been able to find much of a knock threshold when using ethanol but agree egt would be very usable for this scenario....that is where the tuning dance begins when you need to consider how rich is safe / detrimental while having enough advance to keep the flame front where it needs to be....On a sidenote I have seen catastrophic failure when not using ENOUGH advance while burning ethanol fuels....pull too much timing and add too much fuel and things will melt with nearly no sign of a problem (without an egt gauge of course) which in that case monitoring egt would have saved the engine above any other tuning tool...which lines up with what you stated about the excess fuel left in the chamber
For the third time 7.35 on e85 is not 9.37 on the gas scale. And for the second time 7.35 is acceptable on the e85 scale. I think it's slightly rich, but a ton better then it would be at a 9.37 on the gas scale.
Not once did I say that 7.35 WAS NOT ACCEPTABLE....... And for your third time...... I just wanted you to say it again. If was kinda funny. Lastly, Depending on your boost and timing, 9.37 gas scale is not to rich.... Some members run their WOT on E85 with a 6.3 to 6.6......
A freind of mine mentioned the Dis 4 system and thought it would work so we decided to do some experimenting I guess...so far so good but still have the distributor ready if neededWhat did you do to your ignition?
Thanks CalSorry to see this. You were making great progress
From what I understand the balancer wasn't tight enough or came loose...the crank is a older Crower casting with a single keyway that extends into the timing gear slot only 3/16 of a inch and if the balancer comes loose at all this is what happens.Sorry to see this happen. What causes something like that to happen?
Regards,
Shev
