easy FAST C-com question?
fast4d
which key do I hit if I want to automatically adjust a cell in VE so that correction becomes zero (or close to it) while running in close loop?
Thanks.
That would be the L key, but you must use the DOS version so far, be in closed loop and be at a steady rate, no acceleration!. ONly the active cell will change to the correct value, so you need to hit the space bar first to make the cell active for each rpm/ kpa point! Have fun
