ECM Conversion Problems
bigboy25
So.... I seem a bit confused about the conversion for the 86-7 ECM. Do I need the following.......MAF Sensor and Tube, Air Temperature Sensor also?
Please help. Also, when I purchase the scanmaster.....is there a "Buick Tuning for Dummies" section on the information book?
You will need the 84/85 Caspers MAF conversion kit or have Eric at Turbo Tweak burn you a new chip to ignore this sensor. You will also need an 87 ECM chip. Brad
Slight typo mistake, he ment the MAT (manifold air temp) sensor not the MAF. You do not need the MAT sensor and Eric can burn a chip accordingly, it can be added if you want as Brad stated. And yes you do need a 86/87 MAF sensor or an LT1 or an LS1 MAF and a translator.
