ECM ground
mrmixer2
1slowv-6
I'm trying to reach the ecm ground bolt on the p/s head. Anyone know what size bolt this is? Is this easier to reach from above or below the car. Finally, once I do remove this, is their a better place to relocate this? Thanks.
Caspers Electronics makes a "ground relocation" kit, that's worth every penny!!!!! Just for those grounds.
The head size is 15mm. From the top is easier. If you unbolt the trans mount at the crossmemember and jack up the transmmision you can gain another inch or so clearance at the back of the cylinder head. Ditto on Caspers relocation kit.
