ECM Modded for MAP
GNVenom
This ECM has been modified for speed density input. Has not been used since the modification and is ready to go (special programming required to move from MAF to MAP) See Turbo Tweak for chip programming.
No CALPAK or EPROM, no core needed, being sold outright. $150 - send me your paypal address and I'll invoice you.
so all I would need is my 3bar I plugged in place for my alky control kit? and a new chip from eric? Just tell him it came from you modded for map input?
I believe you need a separate 3-bar MAP sensor in place of the mass airflow. Bailey did the conversion and it was originally done for a maf-less MAX EFFORT system, but I believe Eric took over and supplies the chip now. Check with Eric. This ECM should be the ticket.
