Holley Pro Dash Backgrounds
Stock style backgrounds. None of these are to perfect scale.
Idiot lights can be set up using a SYMBOL type gauge. It's done without letters in the name of the gauge and no actual symbol selected. You have to delete the letters and add blank spaces with the spacebar to sort of trick it. I should make a video of how it's done...yes?
Send me a DM if you want the setup file for the last dash background posted. Load the background FIRST in your dash and then load the automatic setup file. It should look exactly the same as the one in the car photo. These were created on a Holley Dominator ECU with a 3.5bar MAP sensor. The boost gauge is set up from 0-30psi. It's extremely important to check all of the gauges to see if they read correct for YOUR car. Use another Holley screen to compare.
Probably the most bad a$$ background I've ever seen after market! Great job
