nailheadpowered
- Oct 31, 2004
Wanted to know what size injectors can be used with an ECM that has had the drivers done. Do you have to pic a size like 72 or 83lb injectors or will an upgraded ECM with the drivers done for low impedence run any size injector? also would that eliminate using high impedence injectors like my 65lb mototrons? thanks.
