ECM with powerlogger and gen II
brian b
Has anyone been able to reinstall ECM back into kick panel with powerlogger circuit board attached and the gen II plug and play harness put on the other side.
It's tight but it can be done..
Did you cut the bottom of the kick panel to allow room for the pl?
Also if your PL moves around its going to give you wacked out readings. I had to hot melt glue it to the ECM and its all good now.
Thanks for the replies, it took a little more trimming here and there but I finally got it into the kick panel without to much pressure on the Gen 2 plug and play harness.
