Any good?  I'm ordering a bunch of other stuff from Summit Racing and it would be convenient if I could pick this up too.
See it here:
http://store.summitracing.com/default.asp?target=/product.asp?d=3&s=242&p=517&searchtype=ecat
Edelbrock Performer-Link timing set
EDL-7829
$49.95
Application:
1977-88 (V6) 183, 196, 231, 231 Turbo, 252 all with integral distributor drive
Description:
This timing chain and gear set is for use with performance or stock cams. It has a solid bushing chain for a true bearing surface that rolls with the sprockets, virtually eliminating chain stretch. The crank gears are machined from SAE-1144 stressproof steel. This has three keyway setting points to ensure accurate timing selection for early or late model vehicles.
Thanks,
-Banning.
			See it here:
EDL-7829
$49.95
Application:
Description:
Thanks,
-Banning.
