I just finished installing my edist box in my syclone.  Unfortunately, I am not getting a crank pulse at the edist.  I am, however, getting a RPM signal at the fast ecu.  Cam pulse is working just fine, provided by an optical trigger mounted in a modified distributor cap.
The crank pulse should be provided from the stock distributor (inductive pickup) and goes through the stock ICM. It would seem my issue relates to how the ICM works below 400 RPM in crank mode. But, to be honest, I am not certain this is accurate.
So, is there something that needs to be added to the wiring to simulate the load or resistance provided by the stock coil for the ICM to send the pulse to edist? Or am I missing something else entirely? I read a post from bruce that said something about using 3 1kohm resistors in the circuit, but I am not real clear if that is the answer here or not; and if it is, where exactly they would go.
edit1: I just did a simple test of putting the stock coil back on, inline with the wiring that goes to the edist. The coil sparks as it should, so the est signal is definetly being sent to the edist box, however, it is not picking it up (based on the lack of a flash of the led).
Any insight on the issue would be much appreciated.
thanks.
chad
 thanks.
chad
