I know that many of you running Aquamist pumps think nothing of running hi content Isopropyl or Ethanol mixtures. Mostly for you guys, I need to relay the following. Ive been working with Aquamist on doing some pump specs. Ive taken measurements of fluid delivery rates and water pressure rates from the .7, .8, .9, and 1.0 mm nozzles.
It turns out that both my delivery rates, and my pressure rates are down from the specs shown in their chart.
Aquamist is telling me that the likely cause, after examining my numbers, is swelling seals, due most likely to my early use of Isopropyl mixtures in excess of 20% which is their max recommendation for that alky. I havent used Denatured, but Ethanol is even worse. Anything over 5% will degrade the pump.
Ive talked to alot of you guys who poo poo this stuff, but guys, its no joke. My 1mm nozzle is flowing no differently than my .7mm nozzle. for instance, the 1mm jet is supposed to flow 335ml/minute. Mine flowed 265ml/minute! I initially used Isopropyl mixtures of almost 50/50. I didnt use it for more than a couple of months, but, apparently, that must have been enough to do it.
Incidentally, we ruled out all kinds of other causes, by taking voltage measurements at the pump both with engine off, engine at idle, and engine at 2K rpms. All my voltage measurements were perfect according to aquamist. We ruled out all else, and its come down to the pump, and specifically to degraded performance.
They'll know more once they examine my pump. If youve been running Denatured in an Aquamist pump, or Isopropyl > 20% strength, I would suggest strongly that you start taking some flow and pressure measurements! You may be in need of a new pump
