May 7, 2009 #2 S street6 pushing stock limits Joined Feb 13, 2009 Messages 203 cottonsperformance.com $14.95 is what is listed under his website (product #CRH-B1201). fullthrottlespeed.com may have them as well.
May 8, 2009 #4 T turbo6man Member Joined Jul 3, 2001 Messages 233 gasket?? Are you guys running the block off plate with a stock gasket or anything?
May 9, 2009 #5 T "Turbo-T" V6 on steroids Joined Jan 10, 2007 Messages 7,393 I put mine on w/o a gasket and tightened it down. No leaks here.
May 9, 2009 #6 S street6 pushing stock limits Joined Feb 13, 2009 Messages 203 I guess one could use a little sealer if they like.
May 9, 2009 #7 PaCemkr86 WFO Racing Staff member Joined Jan 19, 2005 Messages 4,368 the one cottens sells is very nice !
May 9, 2009 #8 E ET/MPH New Member Joined Dec 21, 2005 Messages 8 What's the purpose of blocking off the egr.
May 9, 2009 #9 PaCemkr86 WFO Racing Staff member Joined Jan 19, 2005 Messages 4,368 helps clean up the engine, Most chip dont even use the EGR function anyway And when you port your intake the egr passage is cut out and the hole is welded up. Its also one less thing to leak
May 10, 2009 #10 Q QUIP'6' Brian Roman Joined Nov 26, 2003 Messages 4,381 full throttle. see the one in my picture
May 13, 2009 #11 P Procharge Boost inspired WFO Joined Aug 11, 2008 Messages 81 i used the one from cottons looks like the one in the pic above, very cool no leaks just used a bad high temp rtv and snug it up a bit should be good
