Blown&Injected
- May 31, 2001
I am trying to figure what is causing the induction backfire. Brand new fuel system and lines but I need a gauge with a long enough line to read while driving because I think it is still leaning out.
Car has ALKY and that seems like it can make an induction backfire something extra special and the last one blew the head gasket.
The EGR is blocked off and it looks like there is still a clear path from the #3 exhaust port to the intake manifold but that is where the block-off plate stops the exhaust flow – right? I blew the Head Gasket on the #3 cylinder and my mind is just knocking ideas around…
I am gonna pull the #3 rod cap and take a look at the bearings – the oil pan was clean except for a bit of junk from the graphite head gasket.
New coil and vacuum lines but the module is at least 15 years old – might be the one that came on the car in 86!!!! Car has been driven just a few times per year for the last 10 years. Don't know what else to consider???
Oh yeah, the PVC is also totally blocked off, I just have big breathers, one in each valve cover. I did not want any dirty air in the intake - maybe I went too far???
