After reading thru some cold start hesitation threads, I supected my EGR. I took off the black cover, put my thumbs on the top and forefingers on the bottom so I'm holding it like a sandwich. Nothing moves if I squeeze. I went on to the center of the bottom. Feels like a little arm that would push-pull the valve. No motion if I push up or down. I blew into the vac hose and I could feel the rubber diaphram around the edge move, but no metal parts move. ??
I am assuming that the arm is just stuck and I need to remove and clean it up. Is this possible?
Car runs great after 3 minutes of warming up, just a hesitation when cold. Also, it doesn't hesitate cold if I crank it up and run the AC. Would a stuck valve affect WOT performance and knock? I don't know if it open or closed.
Thanks,
Scott
Thanks,
Scott
