captndave737
- Feb 14, 2006
New fan wiring diagram
Factory fan wiring diagram.
I got rid of the high speed fan relay, Fan delay relay, The Power Disaster relay, the coolant fan Temp. switch and all associated wiring and the wiring going to the high pressure side of the A/C high pressure switch.
It's an Intrepid dual fan setup. Each fan has 2 windings. When either of them are powered the fans run on low, when both are powered the fans run on high. I have them wired so the low speed fan relay powers both windings on both fans so they're either high or off. It would be easy enough to run a switch from the battery to the fan relay for manual operation but I haven't had any problems the way it is.
