jacksorroche
- Feb 24, 2003
I found a dual electric fan set up on a 92 Pontiac Bonneville GTE and pulled it to see if it would fit on our cars. Although it looked tight, it seemed like it just might fit with a few extra mounting holes drilled.
Has anybody used the dual fan setup from these or any other car? Will the electrical system handle the load? Will I be able wire it in using the 87’s fan relays? Lastly, could I get some pointers as to which wires I should splice into? I am looking to go with the 87 ECM setup and would like to install the electric fan if possible. I would greatly appreciate all help on this.
