The only car that uses some of the main componets is the 84-87 Pontiac Fiero.
Shroud 85-87 with AC and heavy duty cooling
Fan Blade 84 only with AC
Motor 85-87 with AC and HDC
Top mounting plate is 86-87 IC TR only
The easiest way to tell if a Fiero has HDC is to compare the part number cast in to the shroud which will be 22049524. The HD motor is a 3 wire connector where the STD motor is a 2 wire. Fan blades should be interchangable on the 85-87, the only difference is the blade count. A top plate from a Cutlass/Regal with the 307 V-8 will work but you will have to weld on the top shroud mountings.
A word of wisdom. In the hundreds of Fieros I have seen in the salvage yards, only one had the HDC option. It was an 87 Formula. Those parts are extremely scare. Time might be better spent buying a used setup from one of the vendors.
