Electronic Boost controller features
tacordes
Im considering upgrading my in car manual controller for an electronic one.
One of the main reasons is to have the ability to have 2 or more preset boost levels....
Ive been reading about some of the different features and the failsafes they offer.
The question I have- do any of the controllers have a feature where if any knock
is present it will drop the boost to a lower level.......
This would be good for someone like me who is not the most savvy tuner, might
even save a head gasket or 2....
Negative. If you had a fast ecm and used it to control boost then you could set up something like what you are talking about . Also my sd2 setup has all sorts of features like that . I currently am running a boost leash controller and I love it I traded my Ams 500V2 for it . I like the fact it has a built in bump box as well as a scramble feature.
Thanks for the reply-
I guess I better do some more reading before I buy anything, I sure like the idea that if I get any unexpected knock,
the system would automatically kill the boost....
Im not sure my car is at the level to justify anything like the fast ecm, time to do lots of reading... : )
It doesn’t seem like you need a EBC. They’re not cheap. If trying to get something to save you from detonation I would consider the sportsman XFI. It will add up to 25% fuel if needed. The TT 6.1 wideband chip would also be a good choice. Keep reading.
I use the innovative scg-1 controller. I'm not happy with the boost curve it provides with a 10psi spring but it does have an over boost and air fuel feature. Going to try and tune it on 16psi spring to see if this makes my boost curve a little more steady.
I have the SCG-1 also. It's a nice controller. I have my wastegate spring adjusted to 20psi and get pretty good control. Still trying to learn though. The O2 sensor in the SCG1 reads really close to the FAST O2. I really need to configure gain setting along with duty %. You can make boost hit really hard or soften it up
Hopefully, come about October/November, I'll have some SD2 chip with a TurboSmart EBC tuning questions for you........
Ya'all ready? ;);):D
Nice . Yea I really like my setup . The sd2 has been great as well as my boost leash controller. It’s a great setup that I use as my traction control. I can have the boost come in super fast or slow it down ect let me know if you have any questions and I can try and see if I can help or not
Stay "tuned"...... ;)
Following
I do not believe at this time on the market there is a standalone EBC that has a fail safe for predetermined sensor inputs like; knock detection, overboost detection, EGT lean detection, etc.
If you have an aftermarket ECM there are parameters you can input into it; like if your EGT sensors read above whatever temperature you input as too high or too low, or if your MAP sensor reads a psi level too high, or your wideband reads too lean....you can have the ECM pull timing, or reduce the boost pressure, or add fuel...all things that would help prevent detonation.
I believe the SD2 chips, like DankGN said, also have features like this, typically referred to as "self tuning" or "auto-correct". The old Gen2 Translator had the ability to allow you to preset a target AFR and it would add or subtract fuel to help you maintain that target AFR.
Most new ECMs, like the Holley or MS3, and I believe the XFI too (Cal would be better suited to discuss the XFI's features) have self-learning in them. You can input into the ECM what parameters you want to use as the range of "safe" readings from your sensors (Wideband, MAP, EGT, for instance) and if the engine goes outside these parameters, such as the EGT readings are too hot (which would mean you are lean most likely), or if the MAP sensor reads too high of psi, or the wideband reads too lean...the ECM will automatically either reduce the boost pressure, or pull timing, or whatever you set it to do...this is also why when running external wastegates with aftermarket ECMs they tell you to run a wastegate spring that is about half your target psi, so that if your ECM has to cut the boost pressure as a failsafe, the electronic wastegate solenoids will open and the turbo will only be able to build as much boost as the external wastegate springs allow, which would help prevent any catastrophic failure hopefully.
For instance, I will be running an MS3 Ultimate (not the Plug N Play) on my car, along with EGT probes in each cylinder primary. The EGT probes run their signal to a 3rd party box called a CAN EGT 8, which takes the EGT probe signal, converts it to a 0-5v signal, and sends the signal reading for each of the 6 probes to the MS3 box via the CAN bus communication. I can then program the MS3 so that if any of the EGT's read too hot (which would mean a lean condition) the MS3 will then cut boost pressure instantly, hopefully saving the engine.
But back to your question- as far as I am aware, there are no aftermarket boost controllers that can do this....maybe something like the AMS2000, but I don't know for sure since I am not familiar with it..I only suggest it because the AMS2000 is a $2,000 controller..so it better do something like that for that kinda money! hahaha!
