GregorE
- Feb 26, 2023
Hi everybody!
My 84 Regal has the mysterious Electronic Touch HVAC-system which works fine except for one issue. (Thanks to all the people who already shared a lot of information here concerning the regular AC-controls. This really helped me locate the problem.)
If I choose a temperature only one step higher than the minimum, the blend door opens completely and lets a lot of hot air flow into the cabin. (I watched the little motor move the short arm that opens the door. It’s located right behind the glove box just like the mechanical unit/cable from the non-electronic version.)
If I choose the minimum temperature, the blend door closes completely (just like the heater valve in the engine compartment).
Did someone here experience the same problem?
Does anyone know more about this option?
Does anybody know how to inspect and repair the control unit? (I’m quite sure that it’s an issue caused by this device.)
