calais1965
- Mar 10, 2009
Hello i have few questions of my combo.
These parts i have...
109 block
+30 Je Pistons
h-beam rods
steel crank
GN1 aluminium heads
70 tb
Kb-headers
alky
aeromotive a-1000 pump with 1/2 lines.
Comp Cams 212/212 flat tappet camshaft
pt-70
3" down pipe
Big front mount cooler
billet caps & girdle
New bearings & oil pump
roll master Timing set
Tial wastegate.
What size of injectors should i use with these?
What maf i should use or would maf translator pro be better?
How much hp i can get with these stuff/ how fast can i go 1/4?
What head gasged do you recomend?
Boost?
best converter stall speed?
Have i missed something?
Thanks!
109 block
+30 Je Pistons
h-beam rods
steel crank
GN1 aluminium heads
70 tb
Kb-headers
alky
pt-70
3" down pipe
Tial wastegate.
Boost?
Thanks!
