I would like to hear the consensus concerning how much engine oil I should install in a Buick V-6 which has an RJC Engine Girdle fitted to a 109 Block?
I am using a stock-sized oil pan with a big Oil Filter (AC - PF24). I have also adapted an external oil cooler - bypassing the OEM one in the radiator.
I believe capacity would be ~ 6 to 6.5 quarts - where the dip stick would display a reading that was "happy" - without that 3/4" thick plate (block girdle) bolted to the bottom of the block.
Yet with the 3/4" Plate bolted to the bottom of the block - think I should add an extra quart and attempt to obtain a "happy" dip stick reading - or not?
Would like to hear the consensus on this - please.
I understand that if using a flat tappet camshaft - that adding extra engine oil so the level reaches the crankshaft "throws" is probably important - as flat tappet camshafts receive their lubrication to the lobes by "internal splash" - yet this engine has a billett hydraulic roller camshaft.
I also have the oil pick-up tube extender installed.
Many Thanks !!!
Many Thanks !!!
