Engine "freshening" near So. Carolina
roadrunner88
Who would you recommend (and where are they located) to perform a light rebuild or freshening up a stock engine w/64K?
Car runs okay, plenty of power. No known problems...
I would also like a good bit of the suspension replaced as some of it looks a little rough...
Might be two shops for this, huh?
I'll call all who are referred...
Thanks in advance
Do a search for NCTURBOS. He's a member on the board here and is located in the Charlotte area.
With 64K and no problems, why would you even consider having somebody in your motor? :confused: Want more power? Change your valve springs and replace your original timing chain set.
I guess I'm a little unclear the way I expalined it.
I'd like someone close enough to haul it to that can thorougly check it out and give it a major 'spring cleaning' type tune up, and suggest some mild upgrades for reliability...
And replace some questionable looking suspension parts...
Hope that's clearer... I don't want a 'rebuild'... :)
