Engine Harness plug ID
buickspec6231
Hello all I have three plugs on my hot air harness I am looking to identify. The first two are (1) 4 pin male weather pak and (2) 3 pin male weather pak connector. These two plugs are coming out of the same part of the wiring harness as the C100 bulkhead connector. The last plug I need identified is a red male 2 pin connector on the end of a long lead which exits the same part of the harness as the MAF sensor wiring. I'm just looking to get these plugs labeled as it will be a long time before the harness is installed back into a vehicle. I have all the other plugs identified. Thanks for your assistance.
Top pic looks like PowerMaster. Most of the 85 harnesses I've seen had them even if your car came with HydraBoost brakes. Bottom pic I'm guessing is for the Evap canister solenoid.
I can't id the first pic but the second one is definatly the evap canister that mounts just under the maf on a bracket, I moved my canister to make room for my cold air kit, so I recognise it.
