OK, I have a new issue that I can't readily find so I'm looking for suggestions.
See specs in sig.
Symptom- accelerating slowly like in pulling away from a light or after going around a turn the car stumbles and misses. Doesn't backfire or anything that drastic, just stumbles all over itself. Fuel pressure appears normal and so does voltage. Voltage was low and alternator not charging up to snuff (10 years old) so thought that might be the problem so installed a new alternator. Same issue.
Car has Welbro intank pump hotwired.
What makes this weird is when accelerating slowly and stumbling, if I give it enough throttle to get it to about 5-10 psi boost and keep it in boost mode, it smooths out, pulls hard and runs like it normally does. Let off and ease back into the throttle, stumbles again (almost seems worse that before) and takes about 20 secs to get back to normal stumbling. This makes me think it is getting fuel and current.
Only changes made to the car recently were replacement of an old SMC alky kit with a new Razor kit (including 3Bar) BUT it ran good after the install for several months. Only other change right before this started was putting in a new powermaster brake accum ball (could I have dislodged something around there)?
Looking for ideas on what to check. Also - no codes on scanmaster,
Many thanks.
See specs in sig.
Many thanks.
