Here is my build sheet mid to high 9's:
Part Description Cost
Stroker Crankshaft CAT231A 3.625 $450.00
10 over JE Pistons 8:5:1 Compression $480.00
JE H.Duty Wrist Pins $100.00
3.810 Ring Set $100.00
RJC Girdle
RJC Underdrive Pulley
70 MM Accufab $500.00
Buick 6.350x.927 K1 Rods $490.00
V6 Buick Main Bearings
Federal-Mogul Wide Journal Rod Bearings
BHJ Internal Balancer w/Trigger Wheel ENGBHJ-int or ATI $405.00
JW Flywheel (SFI Certified) JW93007 $200.00
Champion GN-1 14 Bolt Aluminum Heads HE100-14 $1,600.00
Push Rods Guides $150.00
ARP Head Studs $150.00
Scorpion Roller Rocker Set Up $300.00
Head Porting $500.00
Billet Roller Comp Cam (If Needed) 234/234 580 lift $350.00
Comp Push Rods $85.00
H&R Motor Mounts $200.00
LT1 Starter $135.00
DLS External oil system $550.00
CSR Trans Sheild $280.00
SX Fuel Pump $500.00
SX Regulator $144.00
SX Fuel Filter $80.00
Fuel Cell $250.00
Lines and Fittings $500.00
Champion Alt Bracket $250.00
RJC Underdrive Racing Pulley $149.00
MSD Voltage Booster $305.00
Aluminum Oil Pan $625.00
Meizere Water Pump, Inlet, and Relay $438.00
TA Stainless HEADERS $1,025.00
Header Ceramic Coating - NitroPlate $200.00
Champion Fuel Rails for Stock Intake $249.00
Cometic Head Gaskets $150.00
Limit Engineering GTQ-70S TURBO .85AR $1,450.00
4 Inch Cold Air Kit Polished $285.00
Fast Fuel System With extras $2,355.00
GN Performance Radiator $450.00
Build Labor for Engine $1,200.00
Coolant Tank $35.00
Vacuum Block $42.00
200 AMP Alenator $450.00
HR Sway Bar $550.00
Moroso Front Lowering Springs
Adjustable Drag Shocks
Mosler Axles, Welded Spool
Ultimate Diff Cover with Supports
Stock Ring Gear 3.42
3.5 inch Down Pipe and Coating - $585
Cost $19,292.00
All purchased through Kip Asplund, Cotton's, DLS, and Hartline. Jegs for all the fittings and non buick specific stuff.
Billet caps - Kip can get you some. Kip on the board
