My engine is all apart and going to its several places to get treated. The block has been dipped, the drank is being rounded and heat treated, the heads are being surfaced and possible getting a 3 angle job. I just bought the two center main caps and .20 over diamond pistons along with the whole ARP bolt set up. Im planning on using the comp cams 980's valve springs and thats about all thats going on in the engine department. My first question is, being a daily driver and a strip car just about every weekend, what would be the beste size cam for me?
Also, the rest of the car is going to get the usuals, nitto 555r's, cold air system, dump pipe, chip, a 340 or 307 fuel pump, rear air bags, adjustable wastagate, and some others, including just about every gauge needed for monitoring these things. Boost, exhaust temp, oil pressure, water temp and fuel pressure. I have a laptop hooked up to it for readouts and what not. I was just wondering if anyone had the same type of combination or something close and could give me an idea of what kind of power im looking at or even strip times. Also, i was wondering what kind of prices i would be looking at to get the trubo remanufactured. Any input would help. Thanks a lot guys.
