Antbankstwo3
- Oct 23, 2011
This is a non Turbo Buick related question. But I wanted some feedback. I have a '71 Buick Skylark that giving me some starting issues. Within the past month, I have replaced the battery, ignition key switch & tumbler, the actual ignition switch on the column, all new wiring, battery cables & neutral saftey switch. Alternator was also, just serviced & checked out.
Sometimes when I turn the key, the starter just clicks. Sometimes it will do once & start, other times it will do it several times & start. It even will click then start immediately with one turn of key. It was kind of doing this before replaced battery & neutral safety switch. I'm so confused right now. Any ideas would help. Thank you!
