engine stop when turn right
tybob
hi ..... small probleme my engine stop running when i turn right....any idee ! i check my ground,baterie,fuel pump and line ! mayby a small trouble ......thanks :biggrin:
Check your...
positive cable to the starter, sometimes it rubs against the starter guard and shorts out. While you are down there, also look at the fuseable links as they have a tendency to clear at the most un-oppertune moment.:smile:
