I got a 86 gn a few months back and the motor/trans was pulled by the previous owner to replace some gaskets (he didn't know what he was doing). When he put it back in he didn't hook everything up cause I got some wires that don't go anywhere and I think the vacuum line isn't hooked up? The car does not run right at all, I have no boost in first and second gear. I don't know if that's due to the fact that it hasn't been tuned (I don't see the point in tuning it right now due to all the problems), but could the trans have something to due with that because it shifts way to early and needs to be rebuilt, or cause it has a slight boost leek. I just replaced the cam sensor cap because it was broken but still the scan master says it's not right, and that's the same deal with my MAF sensor I replaced it but still not reading right. I just want to get this running back to stock. I don't know how the inside of the motor is but from what I've seen so far it can't be good. What parts should I replace to be sure it won't blow, I have a feeling that it might have a slight knock but that might be due to the cam sensor cap not reading right.
What do you guys think?
