Tim Cucci
- May 24, 2001
My car suddenly developed a bad skip six months ago while pulling out of the neighborhood. I parked the car until recently while I have time to check it out. New battery, swapped chips, swapped plug wires, inspected plugs. Still missing badly. I pulled the cam sensor and swapped out with a brand new one. NO start condition. Old sensor looks fine. Pulled valve cover , pulled number one plug, rolled engine up to TDC "0" mark on plastic indicator, reinstalled old and / or new cam sensor with window facing 4 O clock position (drivers side) several times. Put everything back together , still no start. Engine rolls over with maybe one back fire but that is it. Now I can't even get to the Bad Miss Issue. Need help.
Comp Cam Roller Kit
TA 49
V4 IC
TH DP
50lb. MSD Inj. w/ several chips
P/P Stock Heads S/S Ferra Valves
Old Alky Kit
Many other mods
Comp Cam Roller Kit
TA 49
V4 IC
TH DP
Old Alky Kit
Many other mods
